Is it just me that finds Flac or Wav downloads ruined by the sound of bluebottles in the background!!
orbis72 said:Is it just me that finds Flac or Wav downloads ruined by the sound of bluebottles in the background!!
Craig M. said:CnoEvil said:Craig, the track was downloaded directly from Linn Records @ 320k; 16/44 and 24/48. I have played this comparison to quite a few people (just to get a handle on how it's perceived). I personally find a subtle but noticeable difference; my wife thinks its "totally obvious"; and my female cousin (who is older than me), could hear no difference whatsoever. Most people can hear a difference (including the daughter's boyfriend).....so it appears very individual.
it would be interesting to see if the same differences existed if you did the conversion from 24/48 to 16/44 and 320k yourself, i have always got better sq converting an existing cd to mp3 myself, rather than buying that mp3 from itunes or similar, even at the same bit rate. :O
hi i am not a techie but i had a sony minidisc player and i found theMajorFubar said:How did Minidisc work? Didn't that use some kind of lossy compression?
Reason I ask is I've still got one of those and actually I prefer its sound to MP3.
Not sure what that says about my ears as I'm sure someone's going to tell me that 320K MP3 is lightyears ahead of the Victorian technology using to compand the audio to/from MDs 🙂.
snivilisationism said:I think this is important. If a business is reliant on the higher quality files sounding better, then it's not too much of a conspiracy theory to perhaps guess that they maybe made artificially better (although I am definitely not claiming this to be the case).
I have a few Linn downloads. They all sound stunning. But if I resample to 320 kbps MP3, they still sound stunning (as do their streaming radio stations (320 kbps mp3). I tried the same thing with the HDtracks sampler last night...same result. Great quality, not in any audible way (to me) compromised by the compession.
Time for a syringe maybe?
But then I was reading up on the science of digital audio, and as has been mentioned, the 24 bits over 16 is irrelevant, as only a small portion of the available dynamic range of 16 bits is actually used, and the only difference with 44.1 and 96 Khz, is that the upper frequencies are extended to double ie over 40Khz. Now call me a deaf old fart, but the last time I checked, I couldn't hear anything above around 16 Khz.
Time for me to stop worrying about hi-res downloads I think.
CnoEvil said:snivilisationism said:I think this is important. If a business is reliant on the higher quality files sounding better, then it's not too much of a conspiracy theory to perhaps guess that they maybe made artificially better (although I am definitely not claiming this to be the case).
In case it's of interest, Linn's description of why their Studio Master sounds better, can be read here: http://www.linnrecords.com/linn-what-is-a-studio-master.aspx
snivilisationism said:It's not a very good explanation. The fact is, CD is 16 bit. That gives a dynamic range of 96 db... Now there hasn't been a piece of music made that can utilize that, and if it did, in order to hear the quietist sounds, you would have to have the volume so high that your head would explode when the loudest sounds kicked in. So dynamic range increases are not needed.
The 96Khz (or more) simply adds frequencies that are inaudible. There is no "filling in" of data, the same algorithm is used to create the tracks...
http://en.wikipedia.org/wiki/Nyquist%E2%80%93Shannon_sampling_theorem
So the 2 advantages of 24/96 "for playback" are 1. Higher dynamic range - Totally unnessary and 2. Frequencies above 22 Khz - Dubious advantage...unless you believe that these ultra high frequencies can be "felt"...maybe they can, but not by me so far.
To add to that, the human ear can not detect volume differences of less than 0.5dB or even 1dB, according to some studies. Let's be generous and say that it's closer to 0.1dB. Now, even assuming a much too wide acoustic range from -20 to 140dB SPL (complete silence to well above the pain threshold), a resolution of 1600 steps (11 bits) is all that is required to represent the entire range of human hearing! Sadly, the pcm signal on CDs is linear, not logarithmic. So in order to achieve this with pcm, you must allow enough resolution to represent a 0.1dB increase (1% increase in amplitude) across the entire range. And for that, you need to discard values above 65000 (95dB) and below 100 (40dB). So it seems that the usable dynamic range of 16-bit pcm is actually closer to 55dB. For 24-bit signals, the usable range is closer to 104dB.snivilisationism said:But then I was reading up on the science of digital audio, and as has been mentioned, the 24 bits over 16 is irrelevant, as only a small portion of the available dynamic range of 16 bits is actually used, and the only difference with 44.1 and 96 Khz, is that the upper frequencies are extended to double ie over 40Khz. Now call me a deaf old fart, but the last time I checked, I couldn't hear anything above around 16 Khz.
tremon said:But like others have said, the quality of the production matters much more than the format in which it comes. Steely Dan's Gaucho in 128kbps mp3 still sounds better than RHCP's Califonication in flac.
tremon said:Steely Dan's Gaucho in 128kbps mp3 still sounds better than RHCP's Califonication in flac.
CnoEvil said:I come from the "vinyl generation", and have been waiting a long time for the sound to get back to the quality that I enjoyed from my TT in the 80s and early 90s..... this is of course a personal viewpoint. IMO.With the advent of high-res music, this is now happening. On AV, you only have to compare DD with True HD to hear what these hi-res formats can do. Anyway, I thorougherly respect and understand your stance on this, and am certainly not claiming to have the answers. Cno
steve_1979 said:tremon said:Steely Dan's Gaucho in 128kbps mp3 still sounds better than RHCP's Califonication in flac.
Sorry for going off topic a bit. But is it possible to get good quality versions of the Red Hot Chili Peppers music? I have most of their albums but the CD's are to clipped and distorted to enjoy properly.
snivilisationism said:The thing is, that is all to do with recording and mastering quality. A CD is already "potentialy" higher resolution and far better quality than any vinyl. The only reason a vinyl version of an album would sound better is the way it's been made. All things being equal and CD trounces vinyl. But as Steve says above, there are some shockingly unlistenable CDs out there.
TALON1973 said:yes....theres this round thing called vinyl 😉
CnoEvil said:snivilisationism said:The thing is, that is all to do with recording and mastering quality. A CD is already "potentialy" higher resolution and far better quality than any vinyl. The only reason a vinyl version of an album would sound better is the way it's been made. All things being equal and CD trounces vinyl. But as Steve says above, there are some shockingly unlistenable CDs out there.
The resolution of Vinyl is (in theory) infinate. Soundwaves, by their nature are Analogue, so this can only be turned into digital by taking a series of "snapshots", which approximate the soundwave with a series of steps. Apparantly, some sounds that have very quick transitions, such as a drum beat or a trumpet's tone, can be distorted because they change too quickly for the sample rate. Vinyl, provided its kept in the Analogue domain through the mastering, needs no conversion and reproduces the waveform intact.....though this method also has inherent problems. This is probably a rather simplistic overview, which I'm sure others who are more knowledgeable can elaborate on.
MajorFubar said:It's not too difficult to justify a sample-rate higher than 44.1kHz. While only the young and privileged can hear upto CD's 'Nyquist limit' of 22kHz, most of us can probably hear up to 10kHz+, frequencies which are at most represented by just four distinct samples per second (there’s no such thing as .41 of a sample). That's not very many at all and is the reason why, as far as I can tell, when I have directly compared 44.1kHz to 96kHz, it's the high frequencies (8k+) which 96kHz seems to reproduce more cleanly.
A 96kHz digital file has over twice as many samples-per-second at any given audio-frequency than 44.1kHz no matter how you look at it. So no, the sounds are not exactly the same. They in fact become more proportionately disparate as the audio frequency increases.snivilisationism said:They don't use the extra to sample more per second at a given frequency though. The sounds you hear at 8khz(for example) in a 24/96 recording are exactly the same as those in a 16/44.1.
You've totally misread what I typed.snivilisationism said:and where you got 4 samples per second is beyond me. It is, by its very name, 44.1 thousand samples per second.
MajorFubar said:A 96kHz digital file has over twice as many samples-per-second at any given audio-frequency than 44.1kHz no matter how you look at it. So no, the sounds are not exactly the same. They in fact become more proportionately disparate as the audio frequency increases.snivilisationism said:They don't use the extra to sample more per second at a given frequency though. The sounds you hear at 8khz(for example) in a 24/96 recording are exactly the same as those in a 16/44.1.
Not really, though I do confess I made a typing error due to being distracted (by my kids), and for that I apologise: I meant samples per cycle not samples per second, but the basis of what I said still stands: 4 samples per cycle of a 10kHz sound is not very much.snivilisationism said:Possibly, what do you mean with 4 distinct samples per second? Unless for some reason you're dividing 44.1 Khz "sample rate", by 10 KHz "frequency"... That's a bit like dividing 8 by fish. Either way, I can't tell the difference.
The theorem is correct that you need to at least double the sampling frequency, because audio waves have a 'plus' and 'minus' value which one sample per cycle wouldn't capture. But just two samples per cycle most certainly don't give a 'perfect reconstruction'.snivilisationism said:And, the Nyquist-Shannon theorum states simply that you need twice the sampling rate than the highest frequency to get "perfect reconstruction of the original wave". I understood that above that, it makes no difference to the end result as the algorithm will yield the same (perfect result). ie the sound at a particular frequency will be exactly the same. If it isn't, then the theorum is wrong, and someone needs to go back to the drawing board.
Sure. But have you performed a frequency analysis of both signals? Connecting the dots with straight lines as you did will result in many high-frequency components that will be both inaudible and expensive to generate.MajorFubar said:The below screenshot shows two 1/1000th of a second snippets of a 10kHz sine wave. The top one is sampled at 44.1kHz and the bottom one at 96kHz. As you can see, the top wave is not very good at all while the bottom one more accurately represents a truer shape of the wave.
