OK. I gottcha... sorry.It wasn't the OP I was alluding to, it was Kenneth, he was the the poster I was responding to with my original "Don't bother" comment, and my subsequent "unicorn" post👍
Good choice. When I recommend these (or Mission 701's) I mentioned What HiFi paired your amp with them back in 2002. I found the write-up.Hi all,
After some great advice from you guys on speakers, i now have a pair of Mission M72s. So thank you all! I now need to know how to wire them. The speakers are my actual speakers, the amp pictured isn't mine but just an image I found online as I'm not at home right now.
I have four core speaker wire, but I'm not too sure what goes where, both on the amp end and the speaker end. Sorry for asking such a novice question but, I gotta start somewhere!
Thanks so much,
PaulView attachment 6618View attachment 6619
After having worn a Sennheiser Hd 599, the high frequencies coming out from the wafer-thin transparent driver were ridiculous, or maybe it was the upgraded silver cable. So, the thought of looking for a single-driver loudspeaker with similar driver properties and a matching sub-woofer could make a fantastic listening experience in the room. This would eliminate the need for internal crossovers in a dual-driver speaker.Understood. My answer was directed at the posters fantasy with single driver speakers, a one man crusade chasing an unwanted unicorn, ridiculous. I'm sure he's baiting everyone and having a good laugh.
I'm happy I only have one set of binding posts on my amp and my speakers, they do the job nicely.
My2Cents is the best person who could explain.You can't bi wire or bi amp a single driver speaker!
Here is a pic of a single driver. It has a + and - terminal... explain how you could bi wire or bi amp it?
I reckon you might be one of those people that have an aversion to high frequencies Kenneth.After having worn a Sennheiser Hd 599, the high frequencies coming out from the wafer-thin transparent driver were ridiculous
Probably that's the reason why so many vinyl records are still in circulation even from new Artists, as there are people who still buy them for their own. I don't own any though.I reckon you might be one of those people that have an aversion to high frequencies Kenneth.
Hopefully he's got the message now 👍If you have four core in a single jacket, I'd just twist up the conductors so you end up with effectively two conductors (making sure you have twisted together the same on each end). That doubles your cross-sectional conductor area, lowering resistance. Will it do anything? Depends on the cable length (longer cable lengths you should be using thicker gauge, which doing this effectively does), but lowering resistance isn't a negative regardless..
