I'm using MA Silver RS6 speakers floorstanders for a home cinema set up and want to add the rear surrounds. I don't have a lot of space at the back of the room and the RSFX look a bit bulky. Is it possible, or adviseable, to use other speakers - say the Radius HD90 - that are more compact for the rears and still get a good integration? I'm using a Denon 2809 amp.
Any advice from the more experienced of you would be great.
Thanks,
Peter
Thanks,
Peter
