Can anyone help me, I just purchased a Michell syncro & have oiled the platter spindle it spins freely then as it settles it stops & rests flush on the spindle & is very stiff any suggestions? thanks for any help here
			I’d return it! Did you buy it non working?Can anyone help me, I just purchased a Michell syncro & have oiled the platter spindle it spins freely then as it settles it stops & rests flush on the spindle & is very stiff any suggestions? thanks for any help here
Should there be a ball bearing at the bottom of the well where the spindle sits?I’d return it! Did you buy it non working?
It’s ancient now, though a lovely design, but maybe there’s a ball bearing missing from the bearing sleeve? Is the platter at the right height?
Welcome to the forum!
Yes, normaly wolframcarbid steel ball must be below spindle. And several drops of high quality oil. After many years of use, it is good to make precise cleaning of the bearing hole. Than it shall work.Should there be a ball bearing at the bottom of the well where the spindle sits?
I deal in B&O so this is new to me as came in as ptX, worked it out now, thanks for your timeok, thanks
Thanks, I deal in B&O & this is new to me came in as a pt X, worked it out now, thanks for your helpYes, normaly wolframcarbid steel ball must be below spindle. And several drops of high quality oil. After many years of use, it is good to make precise cleaning of the bearing hole. Than it shall work.
If this turntable wasn't fully functional when it arrived why the desire to take it as PX?Thanks, I deal in B&O & this is new to me came in as a pt X, worked it out now, thanks for your help
What means PX?If this turntable wasn't fully functional when it arrived why the desire to take it as PX?
Part exchange.What means PX?
Same reason car showrooms take in old cars as part x, business, £50 the turntable cost me, tone arm is worth £350 on it's ownIf this turntable wasn't fully functional when it arrived why the desire to take it as PX?
Good for you assuming you can move it on.Same reason car showrooms take in old cars as part x, business £50 the turntable cost me, tone arm is worth £350 on it's own
