MF X-CAN V2 - Zero volume?
El Hefe
260
17
18,895
Hi all,
Recently purchased this unit from ebay and have been running it for nearly 5 days now. Really like the warm sound of it.
However, I have a question. Is it normal to hear a very low volume of music coming out of the headphones eventhough the unit volume knob is at zero? FYI, I hooked it up via the tape out of my X-A1.
What headphones are using with it? I have a hybrid amp like your x-can and with my grado's at zero volume I hear nothing but with my lower impedance Denon's I can still hear music out of them at zero volume.
Ahhh it depends on the headphones as well is it?
Well the sound could be heard when I use my Senns and Shure earphones and also BOSE over the ears headphones.
I am sure it is because you have it set up with the tape loop. I had mine connected with one set of phonos into aux. I have also notuiced that I get more background hiis with my Grados as opposed to AKG and Goldring, the Grados at 32ohms having the lowest impedence.
I cant find ratings for Bose headphones for ohms or db/mW to find out the sensitivity. The lower the ohms and the higher the db/mW (or db/V) the more sensitive headphones are.
