stereoman said:
Hello to you...actually, going back on my word a bit. The CD playback compared to my TT is terrible. I use Denon DCD 1500AE which has some digital outputs. Denon make really good CD players but mine is not so new ,so I assume the internal DAC is a bit oldish. Now, the question - if I buy an external DAC up to 400€ will it make a difference and make the sound at least similar to vinyl ? Or is it enough to buy a new CD player with better internal DAC than mine, what would be your suggestion ?
Which CD's are you comparing against which vinyl albums or singles?
If it's 21st century chart topping / mainstream albums then you will find that the mastering of the vinyl version is ubiquitously better from a dynamic compression point of view.
There is nothing that any CD player / transport / DAC can do about that, regardless of the price / engineering excellence.
If you're comparing albums where the CD mastering is equally good or better than the vinyl version then that would imply that your CD player has some sort of technical fault. Try to borrow a different CD player or DAC. Or failing that I'd suggest you check out the Lampizator pages and buy one of his recommended CD players that can be bought for £20 to £50.
Be aware that you can, if you wish, get much better playback from your vinyl from different TT, arm, cart, phono stage combinations. Your Teac TN300 is OK for what it is, but there are much better engineered solutions out there.
