Although no maximum length for an HDMI cable is specified, signal
attenuation (dependent on the cable's construction quality and conducting materials) limits usable lengths in practice.
[117][118] HDMI 1.3 defines two cable categories: Category 1-certified cables, which have been tested at 74.5 MHz (which would include resolutions such as 720p60 and 1080i60), and Category 2-certified cables, which have been tested at 340 MHz (which would include resolutions such as 1080p60 and 2160p30).
[111][119][120] Category 1 HDMI cables are marketed as "Standard" and Category 2 HDMI cables as "High Speed".
[1] This labeling guideline for HDMI cables went into effect on October 17, 2008.
[121][122] Category 1 and 2 cables can either meet the required parameter specifications for interpair skew, far-end crosstalk, attenuation and differential impedance, or they can meet the required nonequalized/equalized eye diagram requirements.
[119] A cable of about 5 meters (16 ft) can be manufactured to Category 1 specifications easily and inexpensively by using 28
AWG (0.081 mm²) conductors.
[117] With better quality construction and materials, including 24 AWG (0.205 mm²) conductors, an HDMI cable can reach lengths of up to 15 meters (49 ft).
[117] Many HDMI cables under 5 meters of length that were made before the HDMI 1.3 specification can work as Category 2 cables, but only Category 2-tested cables are guaranteed to work for Category 2 purposes.
[123]
As of the HDMI 1.4 specification, these are the following cable types defined for HDMI in general:
[124][125]
Standard HDMI Cable – up to
1080i and
720pStandard HDMI Cable with EthernetAutomotive HDMI CableHigh Speed HDMI Cable –
1080p,
4K,
3D and
deep colorHigh Speed HDMI Cable with Ethernet[/list]
An HDMI cable is usually composed of four shielded
twisted pairs, with impedance of the order of 100
Ω, plus several separate conductors.
Extenders[
edit]
An HDMI extender is a single device (or pair of devices) powered with an external power source or with the 5V DC from the HDMI source.
[126][127][128] Long cables can cause instability of
HDCP and blinking on the screen, due to the weakened
DDC signal that HDCP requires. HDCP DDC signals must be multiplexed with TMDS video signals to be compliant with HDCP requirements for HDMI extenders based on a single
Category 5/
Category 6 cable.
[129][130] Several companies offer
amplifiers,
equalizers and
repeaters that can string several standard HDMI cables together. Active HDMI cables use electronics within the cable to boost the signal and allow for HDMI cables of up to 30 meters (98 ft).
[126] HDMI extenders that are based on dual
Category 5/
Category 6 cable can extend HDMI to 250 meters (820 ft), while HDMI extenders based on
optical fiber can extend HDMI to 300 meters (980 ft).
[127][128]
