Matching old and new - MDAC+ and Quad II
John Fulwood
18
10
525
Hi all, I have acquired a couple of Quad II power amps that I intend to have serviced and made able to take a modern pre-amp and mains as the Quad 22 is, according to some, the weakest link and not practical for modern multi-source set-up.
I am thinking of an Audiolab MDAC+ as the hub for this system with an original Sonos Connect to provide the streaming content until I upgrade it. I'll connect it with a digital coax cable. I will also connect an old Sony reference CD player through digital optical.
Question 1 - has anyone got any experiences, good and bad, with linking vintage gear into a modern system? What do I need to look out for?
Question 2 - what does anyone think of the MDAC+? It's been out for a few years, anyone got any intel on if there is likely to be another-one out anytime soon?
Thank you for your thoughts.
John
Gray
That's the relevant bit John. As long as their input sensitivities are suitable for the DAC.
Then the usual power-up rule applies; pre first, power amp last.
Power amp off before pre on switch off.
I've had the original MDAC on home loan (as part of the 8200 CDP - but it's the same thing).
OK though it was, I couldn't justify spending £600 on an MDAC.
The MDAC+ is supposed to be better (as you might hope for £200 more) but I doubt there'd be a lot in it.
Maybe you're looking for a seconhand MDAC+?
Personally I'd be looking to spend way less than £800 on a DAC, these days.
