Roksan amps, old and new
I have tried room correction..
Lyngdorf
DIRAC
WiiM
All attempted with various software, mics, etc and nothing comes close to setting up stereo hifi with the right speakers to suit the room matched to the right amp for the speakers…
Room correction is the easiest, cheapest, and fastest way to make good sound in a bad room. To do this, you do not need to "select" speakers. That is why I consider this function to be the most important in modern audio equipment.
(Personal comments deleted by moderation. Do not repeat.)
Yeah.. ok…which means by default that any amplifier or preamplifier without correction is operating hamstrung and will sound worse than one with………………
Unfortunately my Caspian M2 developed an untraceable buzz. It began after a couple of days in the right channel. I checked all the connections to no avail. Turning it off seemed to fix it, until the next day anyway. Then it reoccurred in the left channel!
It was low level, and unaffected by the volume. To my logic that says it’s not an input or source, but after the preamp. Happened again so I wrote to the seller on Monday. After one more try it was back on the right, so I’ve returned it.
Seller was very understanding, which was appreciated. He had used filtered mains but he has local supply issues which in relatively rural Wales we don’t. All boxed up now and I’ll take it to the Post Office tomorrow. 🙁
Oh that's a shame. Did you have it working long enough to get a feel for how it sounded with your setup?
You did all to mitigate the fault, that's a real shame.
Hopefully you'll find a suitable replacement.
Reactions: nopiano
Not really. Had plenty of energy when I let it have its head! Now I’m pondering whether to buy another one.
It does have few oddities, like red lights mean on rather than off or faulty! And the mute is labelled mode! But it’s likeable. However, the elusive Tape Monitor circuit is present, and it has balanced inputs optionally. But no headphone socket, so a bit strange. I think an ATC preamp might be more sensible.
Reactions: Revolutions
Sometimes quirky can be endearing, although some of those just sound a bit odd. Tricky to find working model to demo now though, and guessing the 4g won't be a good guide.
Talking of ATC, I saw Audio Affair have a used CA2 mk1. Pretty big step-up in budget, but I can only imagine it'll sound good...
Yes, that one has been around for a while but a bit too old for my liking!
PS. Have made an offer on a versatile Arcam preamp. Waiting for a reaction!
On the contrary. Digital correction is almost the only functionality for stereo listening, for which it is worth overpaying
TO be honest, it's really overrated. One of my amps has Dirac, but much better results can be achieved with positioning the loudspeakers and listening seat.
There are a number of reasons why DSP's are not the best option:
- You change the character of the loudspeakers and those characteristics are the reason you bought them.
- You can reduce some peaks in the bass with DSP's but you can never increase the dips. You can put as much as you want in a speaker but if your sitting in a acoustic knot for certain frequencies you will never hear them
- Digital signal processing requires a high resolution input stream because you will loose resolution during processing. Pure maths. If you have 16 bit content, the result will be less then 16 bit resolution
- If you have analogue sources you will ruin the analogue sound completely once it's digitised for processing.
An interesting point, which I probably shared* until recently. Aside from early LPs, what analogue sources do we have? None in my estimation.
FM radio, all sent via PCM. DAB radio, digital by design. CD, digitised regardless of original source tapes. New LPs, cut from digital masters, via digitally controlled cutting heads.
Even fanatical record player makers like Linn, have found that digital RIAA correction is superior to analogue.
* I wouldn’t have said ruined, though!
Everything is produced in digital, it seems.
The needle scratching up against the groove is pure analogue distortion, which should keep the vinyl camp happy. There's something that digital can't touch! 😊
Roksan is an audiophile brand, poor value for money. In addition, there is no DSP processor, which means you lose the ability to adjust the speakers to your room. As you know, your room is 80% of the sound.
If I were you, I would buy the Onkyo RZ30 - this is a modern combine that has everything, including Dirac room correction
Every Roksan amp I've demoed - quite a few - have been great VFM.
