Question Marantz PM7000N - Ideal stand mount speaker?
Chris2021
18
Recently bought a Marantz PM 7000N amp, using it with KEF Q300 speakers.
wish to upgrade the speakers, any suggestions?
seriously looking at KEF LS50, will it be a good match or overkill?
Room size: 3M by 6 M
I do have Atacama stands
Listen to mostly 80s music and a little bit of classical.
Many thanks for any suggestions.
manicm
B&W 606s2 as a sideways improvement but definite improvement. Or a higher end Dali. You actually have a wide choice of speakers with sensible impedance figures.
If you’re looking at the LS50 but have spare cash go straight to the newer LS50 Meta - it’s an improvement and seems to work better with lower power amps as well.
Reactions: rainsoothe
rainsoothe
857
396
19,270
Nothing to add to this, except for the fact that I've yet to hear a bad sounding Marantz + Dali partnership. Maybe audition their Oberon 5 floorstanders as well, they'll take less floor space than the Atacama stands, as they're not that big and are quite unfussy about positioning.
Surly Sid
274
113
2,070
I bought a Marantz PM7000N for my mother 3 weeks ago. It matches superbly with her Sonus Faber Venere 2.0
Sonus Faber don't make the Venere any more. I'd suggest checking out the SF Sonneto bookshelf models.
Reactions: Chris2021
RBinDC
59
22
545
Does the 7000n have enough power to best drive the LS-50s? People have claimed you need 100 watts per channel to do that.
The 7000n is only rated at 60 watts. However, the WHF review confusingly stated that it has a max output of 120 watts. Are they just summing the two channels? Or is this indicating the dynamic range of the power amp?
I have heard the PM7000n drive two B&W floorstanders and they sounded great! But then they are more efficient than LS-50s.
Stuart.W.D
191
123
18,770
I have an older Marantz PM8005 amplifier with the KEF LS50's. Excellent match and no plans to change the combination any time soon. I also find Tannoy speakers work really well with Marantz gear.
