Marantz pm6006+Zensor3 too good?
yes i purchased them and now im thinking ive made a mistake and may have to return them.
well i actually settled on this NA8005,SA8005,PM8005 and the Dali Zensor 3 but as mentioned below he said the Dalis wasnt't good enough for the PM8005 so im having a bit of buyers remorse i didnt want floor standers and this was just in my budget looks like i will have to return them.
Before you return them. How do they sound together?
A good amp, while able to drive more expensive speakers and sound better can actually make cheaper speakers sound very good.
Give it a go and see.
Ive ran wharfedale 220s and q acoustics 2020is with my hegel and it sounded very good.
I would just use the Dali Zensor 3s they are a good book shelf speaker for the money .
i see your spent a nice sum of money already so would hang on to the speakers and use them as a stop gap until your ready to buy something better if your not happy but there nothing wrong with the Dalis
use speaker stands with the Dali speakers to get the best out of them .
yes i did spend a lot and the Dali seemed a far better choice than the Concept 20's (i was torn between the 2) i looked at the opticon 2 but they were too expensive and 4ohms plus the Zensor 3's had more better reviews for the money.
The Dalis were chosen when i originaly decided on the PM6005,CD6005 and the NA6005 but my partner said she would help me get this set up PM8005,SA8005, and the NA8005! (problem is its wired) and my main router is down stairs the Hi Fi set up will be on the upper floor i would need a lenghy cable connected to the downstairs router and i dont want my kids tuggin the cable this while its connected to the NA8005 upstairs.
I was thinking of using an old router plugged in the the NA8005 near it and the wi-fi bridge to the main router downstairs but im not sure how to achieve it.
i also noticed the PM8005 has no digital inputs coaxial or optical like the PM6005 and the NA6005 has bluetooth and WI-FI crazy as my partner offered to help me with the funds to get the 800 series rather than the 600 series i jumped at the chance!!
not even tried them yet still in the boxes!! as i mentioned below my partner was generous to match my budget of £1000 i had for the PM6005/6 CD6005/6 and the NA6005 (with the Dali's 3) allowing me to get the PM8005,SA8005 and NA8005! i couldnt ask her to stretch to more expensive speakers as she was kind enough to do this.....😉
