Marantz PM 7200
Uffington
10
My amp has given me faithful dervice for many years...but now has a problem I can't solve...when playing a cd via my new Q acoustic speakers, some of the info ( vocals ) is missing on the rh channel. I have tried using a different input....aux i and aux 2, same result, but through headphones it sounds perfect. All wiring has been checked and is OK. I si the amp do you think or a speaker faiult...got them Christmas last year and the cd player is a new Marantz cd 6006.
Any help would be greatly appreciated.
Uffi.
ChrisIRL
36
From what you've written it doesn't sound like you've swapped the speakers around, try that. As in swap the speaker cables you have in the ok left speaker into the right. It's unlikely that just vocals are missing. Is there any sound coming from the right speaker mid/bass driver? If no sound at all it may either be the right mid/bass driver is gone, a fault with the LF cable to the right speaker or a fault with the right LF output from the amp.
