Marantz pm 6005 broken optical port
BosleyBoy
I have Marantz PM 6005 amplifier which has a broken optical port. I cannot get a lead into this. I used this for connecting to LG TV and having sound through separate speakers.
Would anyone have suggestion for alternate connection from the the tv to amplifier?
Thanks! Just to clarify.... an optical/optical lead from tv to converter and then coax/coax cable from amp to converter ?
When you had the optical connection, the Marantz was the output and the TV was the input.
The converter is the middleman, literally.
In this scenario, you use the Marantz coax output (instead of optical) to the Converter input, and, the Converter you output the optical to the TV input
Please see my comment(s) below 🙂
