Marantz MCR603 update problem
Hi everyone
I tried to update the firmware via ethernet yesterday, and the screen indicates "Authenticating" for more than one hour.
I unplugged it, replugged, and the screen now indicates
"Connection fail:38
30min 100%
System"
It seems to be stuck on that...
I tried to reboot it, following the instructions manual, by pressing the two volume buttons while replugging it, but nothing happens, I'm still on that screen.
Is there a way to hard reset the system ? Or an alternative before I send it back for repairing ?
I live in France (sorry for my bad english !), bought it in UK, so the waranty is irrelevant here...
Thanks in advance !
Unplug the mains from the back. Plug it back in. Power on.
Wait 5 minutes before starting/re-starting any updates.
If you still get no progress then I suggest you give D&M tech support a call... on +44 2890 279830
Thank you for your quick response.
I'm actually unable to turn it on / off : everytime I plug it, I have no boot logo, it directly indicates the "downloading" message, then the "connection failed".
Therefore, I'm unable to navigate through menus too.
I'll give the support call a try, thanks for the number. I'll be practicing my english that way 😉
