Malaga Home Cinema supplier?
DandyCobalt
203
I'm about to embark on a home cinema installation for the in-laws near Malaga.
Most of the kit will be my own stuff which I'm replacing at home - B+W CM8s, Sony HW15 projector, fixed 3m projection screen that I got cheap from SSAV sale, and Pioneer LX53 receiver as the basis.
All this kit will be heading south in the van of the in-laws, but I want to find a supplier near Malaga who could provide a reel of speaker cable for custom install. I understand they come in 100m reels, and you use what you need, then return what's left and settle the bill.
Anyone based in that part of the world?
macdiddy
87
I'm sure it will be easier and cheaper for you to buy a 100m roll of cable before you leave, you have a van so transporting it will not be a problem.
If you are sure you want to buy it when you get there, then a quick search has turned up the following dealer in the area, worth sending them an email to see if they can do what you require.
http://www.eden-audio.com/
hope this helps
:bounce:
DandyCobalt
203
Thanks macdiddy. My problem with transporting the reel is that I'll need to take back what's left over...on the plane.
I'll drop Eden a line.
Cheers,
DC
