- Aug 10, 2019
- 2,556
- 5
- 0
After reading you reviews I'm thinking of upgrading my mains cable to the Clearer Audio Copper-line but as it is fairly expensive I was wondering which appliance it would be best used on intially until I can afford to buy further ones. The choices as I see it are: TV, AV Amp, Sky Box or PS3. Please can you advise in what order I should upgrade. I was also looking at the Tacima CS929 mains block. Would I notice a difference if I say used the Clearer Audio mains cable on say the AV Amp and then plugged in everything else into the Tacima using the supplied mains cables?
