M-audio studiophile av40 vs acoustic energy aego m ?
Hello
Im looking at buying a set of speakers for my laptop with a creative x-fi sound card.
They will be used mostly for music and to watch some TV/Movies.
Im looking at getting a set of 2.0 or 2.1 speakers (preferably with amp built in):
Ive seen a few reviews on your site:
Acoustic energy aego m
http://www.whathifi.com/Review/Acoustic-Energy-Aego-M-System/
and for the Audio Engine 2
http://www.whathifi.com/Review/Audioengine-A2/
and the Lars & Ivan BK-21
http://www.whathifi.com/Review/Lars-and-Ivan-BK-21/
Im kind of stuck on which to choose - are there any others out there that are better
Im kind of leaning towards the M-audio av40's or the acoustic energy aego m,
I can get both for around the same price,
Which ones will sound better for music?
Thanks in advance for any help
Sammy
I'll be getting a pair of these to connect to my pc for spotify .... was supposed to get a pair a week ago, but had to spend the cash on something else
have read good reviews of these ... and can be bought for as little as £70
Thanks for the reply - will check these out,
How do they compare to the acoustic energy aego m - only as I can probably get an ex display set for around the same price as the M-audio ones?
Sammy3:
not sure how they compare, have not heard them, but just going on what I have read so do a bit more research first ....
I am currently using small wharfedale pc speakers that were bought from Tesco's for approx £20 .... (they should be better than the wharefedales)
Ok thanks 🙂
Ive read a few reviews - and a couple have said they buzz/hum even with no input conected - does anyone else have this problem?
Ive decided to go with the aego as most users seem more satisfied with them than the av40's
Thanks for your help,
topic can now be closed/binned
Sammy3:
keep us updated when your receive the speakers
I have the Aego M 2.1 attached to my TV in the kitchen. I think they're rather good (for the money). Certainly have plenty of welly and very discrete.
