looking for some advice for a home cinema set.
Hello,
I want to invest in a home cinema set and i really could use some advice on this.
I now have a ps3 and a panasonic lcd tv model TX37LZD70F.
I was looking to buy a yamaha RX-V663 amplifier (because it can handle the new blu ray audio formats) with a basic 5.1 set of yamaha speakers.
I would like to buy a set with small speakers so they do not take up too much space.
My budget is something like 630£.
I was also looking at the new sony STR-DG820 that was just reviewed here.
So my question is should i go with the yamaha amplifier or should i buy something else?
If i have a budget like this should i spent more for a descent speaker set and buy a cheaper amplifier?
Can you give me some advice on what to buy?
Should i go for the amplifier and save some money to buy descent speakers?
Is there anyone who can give me some advice pls.
Since i am new in this i can really use it.
Thx
Cofnchtr
146
I'd wait until new amps have been released by a few more manufacturers which can deal with the HD sound formats from your PS3 - then buy the best you can afford while keeping in mind that you will still require a set of speakers.
In the meantime keep saving.
If you want something now, the Sony is a 5* product - I can't see a review of a Yamaha 663 you mention so can't compare the two according to spec sheets. The Sony is around £300 so this would leave you around £300 for speakers and £60 for cables (presuming you have stands or some way of wallmounting the speakers) KEF KHT1005 is a good starting point.
If you can give these an audition but also listen to the advice given by a local audio shop as they can be friends! If you can audition, take some of your own favourite movies/music with you.
Cheers,
Cofnchtr.
Gary233932
37
Belguim look at the Jamo A102 HCS from Denmark about £180 in the UK both amps spec look very close try and demo them, hope this helps Gary
Thank you already for the advises.
I finally made up my mind and i am goiing for a yamaha RX-V 663 with a set of KEF 3005 SE speakers.
Do you have any last thoughts or advises pls let me know?
And a final question.
I have a ps3 so will i hear all the new HD sound formats with the correct settings?
Grtz.
azertyguy:
Thats a radical change in budget !!
professorhat
992
22
18,895
azertyguy:I have a ps3 so will i hear all the new HD sound formats with the correct settings?
From what I can see on the US website, the RX-V663 supports 7.1 LPCM through HDMI so yes, you can get the new HD formats by setting the PS3 to Linear PCM mode over HDMI.
yes it is a radical change of budget.
When i was searching the reviews i always found that the cheaper speaker sets where good for movies and not for music.
Since i wanted to do both i upped my budget after confincing my better half that this was the way to go.
so now i think that i have chosen for a good universal audio system to lisen to music and to watch movies with.
Thx for the comments and the advices.
