Looking for a 2.1 Blu-ray system but......
Hey
I am having massive problems with this.
I dont have a 3d tv, only a 32le4900 from LG, I do not think this supports ARC.
But all the 2.1 Blu-ray systems that are on the market are saying your TV HDMI needs to have a ARC hdmi as they are all 3D.
I only want a basic 2.1 system, maybe up to 200.00 for the bedroom, as just love netflix.
I was looking at this, which I can get for 139.99 : http://www.richersounds.com/product/1-box-home-cinema-systems/sony/bdvef200/sony-bdvef200
But again thats 3D, will I still be able to use ALL these 2.1 systems on my TV. Also the Optical on my TV is OUT only, but it has all the phono jacks, but I do want to take advantage of the DD or DTS. Or even master audio from the Blu-rays.
Any recomendations for a System, and are my worries unfounded ect..
Thanks again.
f1only
278
canada16 said:
Hey
Thanks again.
Hi canada16, i cant see the problem with the 3D Blu-ray player/ amp, the system has Optical IN, so therefore will take the optical OUT from the tv, then put the amp/player into ProLogic mode to get your 2.1 sound.
Arc is irrellevant as the audio from the Blu-ray will be going through the players own amp, it will also play standard 2d Blu-ray dvd, so i would say your worries are unfounded.
The downside only is, it is not a seperate amplifier & player. If you wanted a slightly better all in one system i would go for the next model up BDVE280 & still be within your budget of £200. Both systems will do DTS, DTS-HD, DD & DD-HD, the more expensive version gives better audio options like Prologic II & 3 more speakers making a 5.1 system, IMO worth it for the extra £50.
Regards .. Paul
