Logitech Harmony **
Ah, good, thanks....cor, clever stuff innit?
Andrew Everard:
Any of the Harmony remotes will work all of that equipment apart from the PS3, which will need an add-on remote receiver which plugs into one of the USB sockets, and works on infrared rather than the Bluetooth of the standard PS3 remotes.
I'm a big fan of the rechargeable 895 and 885 remotes, but one of the more affordable battery models would be as good as long as you're prepared to keep changing batteries.
hi ive got the "harmony one" but it dont work the "evoke flow"
It's been mentioned the Evoke remote may use other tech rather than IR to command. The Harmony cannot control anything other than IR without the use of a 3rd party add-on. I believe Logitech are currently producing a dongle to operate the PS3 (which uses bluetooth technology) so there's hope for PS3 users yet...
Pure may or may not have such a device available for it's range.
Cheers,
Cofnchtr.
Thanks cofnchtr it would be good if there was a dongle for the evoke
It's also worth saying that you can check on the logitech site what equipment it can control
