Hopefully there are some Elements users out there who can help with a little problem I have.
I have a Leema Elements Integrated Amp with DAC fitted. I am having trouble using the AV mode input. I have assigned AV mode to Input 1 and connected it to the PreOut on my AV amp. The first time I use AV mode it correctly works. However if I change input then the fixed gain is not correctly set.
Here is what happens:
1) Turn on Elements and configure Input 1 as AV.
2) Press AV on remote control.
3) Elements switches to Input 1 and volume ramps up to 127.
4) Press 7 on remote to switch to Optical 1.
5) Elements switches to Optical 1 and volume drops to 30.
6) Press AV on remote control.
7) Elements switches to Input 1 but volume stays at 30.
Turning the Elements on and off again does not fix problem.
