I was a bit surprised that Denon didn't have its community forum, like Sonos. I haven't found one like that anywhere. Well, nothing, I'm trying here, maybe someone will help, I've already tried writing to Denon support, but only AI responds and refers to the FAQ or the distributor, and the distributor is silent 😞
Generally, I want to check this option, which is described in the manual as "Quick Start Mode" - it should turn off the power to the modules (Ethernet, WiFi, Bluetooth, USB) if we do not use them. Unfortunately, the manual describes the shutdown conditions strangely:
"After around 20 minutes of no operation and no network access after playing music via Ethernet",
"After around 20 minutes of no operation and no network access after playing music via Wi-Fi.",
"After the Bluetooth connection is disconnected and there is around 20 minutes of no operation and no network access after playing music via Bluetooth."
And now two questions, please:
- does "...and no network access..." above apply to network operations in general? So, for example, if I use the app on my phone via WiFi to control what is to be played on the speaker, it will assume that network access is being used and will not disable any module?
- does the above mean that when I just turn on the speaker, after not using it for about a day, it will still have all these modules turned on for 20 minutes (and will broadcast via Ethernet, WiFi, BT)? And it will stop them after that "20 minutes"?
And one extra:
- the speaker's manual states that Bluetooth on the phone must be turned on when using the HEOS application. Is that necessary? Isn't it enough to just have Wi-Fi turned on on your phone? The speaker will be connected to the network via Ethernet.
Would be very thankful for all that have that speaker and can check it practically.
Thank you in advance and best regards!
And one extra:
