My friend has bought the KEF wall brackets that are made for the IQ10 speakers...
But it doesn't come with the screws to use when you screw the bracket into the speaker cabinet (yes, I can't believe it either...[:O]) Yet it is supplied with the wall fixings!!!
Anyway, has anyone done this, and what length screw did you use into the speaker cabinet?
Thanks....
Thanks....
