Just when you thought it was safe...
JoelSim
767
Along comes cablespike
And I was wondering what to ask for, for Christmas
http://www.cablespike.com/Gallery%201.htm
Mind you if I do, that will confirm her suspicions that I am a nerd
JoelSim:Along comes cablespike
...For when you have actually stopped listening to 'music'
wouldnt a spike actually increase "vibrations" to the cable
that said i dont think id care
Surely there is a design flaw in that each cablespike should come with its own 112.3656mm by 110.546472mm by 15.282376mm granite block which itself is drilled to accept four corner spikes, allowing true audiophiles to build up multiples of granite blocks for completer isolation and so add true open-ness-less-ness and clarity to their new basshunter cd tracks 🙂
pmarb:
Well said, and welcome!
pmarb:
Surely there is a design flaw in that each cablespike should come with its own 112.3656mm by 110.546472mm by 15.282376mm granite block which itself is drilled to accept four corner spikes, allowing true audiophiles to build up multiples of granite blocks for completer isolation and so add true open-nehss-less-ness and clarity to their new basshunter cd tracks 🙂
I think you've just created the design specs for the all new "cableblock", better patent it quick
