gel said:
No, no I just demoed for the fun of it. I will definitely go bigger next time and plan to spend £3000-£4000 on a 65-inch. I have decided to wait at least 2 years because Panasonic prices will drop dramatically I would like THX setting too, I don't suppose you know if this disables the pixel orbiter on the Panasonic? I am also really enjoying the new settings you gave me - cheers!
I wouldn't worry too much about THX certification.
A lot of it is branding and there's no guarantee a THX preset will more closely match the industry standard than other picture modes. Non-THX certified televisions usually have cinema, pro, or ISF presets, which are pretty much equivalent to THX.
Take the S series Panasonic plasmas, for instance. They weren't THX certified and didn't have ISF picture modes, but the cinema preset, once calibrated, could produce reference level results, or so close to reference that you couldn't tell the difference by eye.
Unfortunately I don't know about the pixel orbiter function on future THX presets. I wouldn't get hung up on this, though, for the reasons stated above.
I'd imagine all Panasonic OLEDs will have ISF picture modes that will be at least as good as any THX preset. And I'm guessing these ISF presets will incorporate pixel flipper/orbiter technology.
