Just connected up the new STR-DA3400es.......
Gerrardasnails
295
..........and it has the Sky HD issue!!! No surround sound through optical. Claire, do you know if there is a firmware that Sony can offer? Also, did your testers find out whether you could assign component to the optical cable? I really don't mind doing that if the firmware thing means sending it back and waiting.
Gerrardasnails
295
Gerrardasnails:..........and it has the Sky HD issue!!! No surround sound through optical. Claire, do you know if there is a firmware that Sony can offer? Also, did your testers find out whether you could assign component to the optical cable? I really don't mind doing that if the firmware thing means sending it back and waiting.
Ignore me - either I found out a way around it or it's just not as clear as Sony normally does things.
So far, cracking sound. Still waiting on BD player to come though.
digigriffin
9
So what did you do?
Just in case I fall down the same hole
Gort1951
2400 owners have said an Ademden (spelling?) is included explaining how to assign the opt/co-ax inputs instead of the default hdmi.
Gerrardasnails
295
Gort1951:
When you go to the assign inputs section. HDMIs 1-4 don't let you assign. However you can assign another way. There are also SAT, DVD, BD etc., that you can set up. I assigned HDMI 2 and Optical Digital Video 1 to the SAT icon. Now I just click SAT on the remote and I get Sky HD with surround sound! It sounds excellent - a very fast accurate sound. I've only had a quick play with a dvd and some recorded HD programmes. The GUI is brilliant.
