ITV HD
breeze
I have just had my Sky HD EPG update and followed the instructions kindly posted on here for receiving ITV HD. I get to having channel 10510 in `other channels` but when I press select it says, No satelite signal is being received.
Am I making some basic error or are some Sky STBs unable to receive freesat broadcasts?
My STB is Amstrad.
Clare Newsome
1,657
By 'power off' do you mean unplugging from/reconnecting to the mains? That's the sort of hard-reset typically needed when you get a 'no signal' message. Leave it a minute or so when you plug it back in and go from there. Good luck (and apologies if you knew all that!)
daveh75
If a power off doesn't work, try removing/deleting ITV HD and then re-adding it.
You remove it,by going into "other channels",highlighting 10510 then press yellow to remove it.
Then follow the instructions to add it again.
daveh75
breeze:
Thanks for your responses Clare and daveh75.
Deleting and re-adding worked. I now have ITV HD logo.
Thanks again.
nice one....Now the hard bit,waiting for ITV HD to actually broadcast something
ukdavej
73
daveh75:nice one....Now the hard bit,waiting for ITV HD to actually broadcast something:p]
Ooo harsh - however, sadly true
