dan 77:maxflinn:dan 77:
Hello everyone,
This is my first post and I must say that I am new in hi-fi, and of course I have a problem that I hope will help me solve.
Since 1 year ago,I have a Nad 326 bee with Monitor Audio RX2 (with a very solid stands),and speaker cables is made from copper.Music,(from disco to classical music) i listening from my laptop (FLAC or CD) via CA DacMagic,and QED performance 2 cable as interconnect.Living room is about 20 square meters.My problem is with the disappointing result meaning that the bass is too "boomy",the trebles is a little painful,metallic and overall I find them a fatiguing listen.I have to say that the distance between speakers and the back wall is 15 cm (my space is very limited). So what I should do to improve sound?If I change MA with Dynaudio dm 2 / 6 (or 2/7) will be a good thing?This Dyns are fussy about positioning? I listened to some Dynaudio speakers in the past and I like it. Or should I upgrade my amp to Yamaha a-s500?Or both?
Thank you in advance
P. S. I apologize for my English
i know exactly what you mean re. the metallic, fatiguing sound from the monitor audio rx's, i had a pair of rx6's for 6 months and good as they were i couldn't live with them, but my room is quite hard and reflective so it may not have been totally the fault of the speakers.
a change to dynaudio dm 2/7s has been a revelation for me, i love them, no boom just nice tight bass which is deep too. no harshness or listener fatigue either, the treble is very detailed yet silky smooth, and there's a wider soundstage, more seperation between instruments, imo they are fantastic speakers..
i've had mine right up against a wall with no boom at all. i run mine with an as-500 btw, though as rick said the c326bee may be perfectly good enough, they are 4ohm speakers but an easy load..
Thank you for reply maxflinn,and i have a question for you,since you have Dynaudio DM.In my case i'm sure my speakers must be replaced.The problem is the dealer who have Dyns in not in my region and DM 2/7 is out of stock(only 2/6 is available).Why do you chose the DM 2/7 over the 2/6?
well seeing as i was going from floorstanders to standmounts i thought i might prefer the slightly more bassier sound the 2/7s put out compared to the 2/6s.
