Mains-cables in HiFi are a long-standing "Bone of Contention".
The most often heard argument against the use of special Mains-Cables
is that they cannot possibly make a difference after all these
miles of lousy cable all the way from the power-station.
And as usual, this is as much true as it is untrue. The long lines
are not that long (what matters is the Cable to the Transformer
feeding your house). In addition, much of the effects mains-cables
have can be traced back to RFI and noise-loops.
The cables that are supplied do indeed transmit the electricity in exactly the same way as expensive cables, after all they are only conductors (wont even go into cryogenics and supercondutors here), many of them do indeed also come with ferrite clamps at either end of the cable just after the wall plug and the IEC connector. Why do they fit ferrite clamps?? To reduce interference which is created by various outside forces, magnetism, computer chips, etc all have very noticable, and measurable effects on the household mains circuits.
When you buy an expensive cable you are paying for the research and the screening / shielding of the cable which "prevents" any RFI or outside pollution to varying degrees. You are also paying for better quality connections and usually hand made and tested with ten years gaurentees, unlike mass produced cables.
Yes, no doubt that the componants dont cost nearly the cost of the cable, but it is a business not a charity. Remember if you give a Chef a recipe, he will always insist on the best ingredients to make it taste "special", we all now this to be true as the same Chef with poor ingredients "Potatoes are potatoes" arguement would taste the difference. This too is not provable scientifically it just is.
IMO mains screening and shielding is AS important as the shielding of Speaker cables and interconnects.
