Al ears said:However if the OP wants to spend money then who are we to stop him.
that's absolutely fair enough as well. If ellisdj wants to spend his money then I ain't gonna stop him 🙂
ellisdj said:Its the Linear Power Supply powering part of the audio Pc thats my point of initial interest - placing the LPSU ontop of a thick slab of ploystyrene has made a positive difference - therefore a properly designed solution should benefit far greater
ellisdj said:ellisdj said:Its the Linear Power Supply powering part of the audio Pc thats my point of initial interest - placing the LPSU ontop of a thick slab of ploystyrene has made a positive difference - therefore a properly designed solution should benefit far greater
Thanks for the sensible suggestions - ordered the ion hair dryer and am hoping it will help with my hair loss therapy.
BenLaw said:And the vibrablock damper:
http://www.machinadynamica.com/index.html
I have reposted the above to try and bring some sense back to the thread. The snake oil brigade do really get on my mits - why bother posting stick to threads you are more interested in, that you can bring positive messages to.
Covenanter said:ellisdj said:ellisdj said:Its the Linear Power Supply powering part of the audio Pc thats my point of initial interest - placing the LPSU ontop of a thick slab of ploystyrene has made a positive difference - therefore a properly designed solution should benefit far greater
Personally I just can't bear to see nonsense being promulgated. Others can speak for themselves.
Chris
PS I had to Google "hard knee house curve". Wonderful stuff.
OK, now I'm more calibrated to your requirements, I'd recommend you try these:ellisdj said:Wow that thing is crazy and butt ugly - thats a bit ott even for me
I had something more like this is mind
lindsayt said:OK, now I'm more calibrated to your requirements, I'd recommend you try these:ellisdj said:Wow that thing is crazy and butt ugly - thats a bit ott even for me
Car tyre inner tubes under whatever boards are supporting your equipment, inflated to about the right pressure. You can buy them for £7. I've seen and heard this approach used with a £12,000 vinyl source.
Sometimes commonly available alternatives are at least as good as more expensive dedicated items.
ellisdj said:People dont read before writing - I am guilty of this as well but I have covered this several times
Read Bad Vibes in Stereophile - all products need isolating from themselves and other products.
Here we go again with the counter argument.....
ellisdj said:Covenanter said:ellisdj said:ellisdj said:Its the Linear Power Supply powering part of the audio Pc thats my point of initial interest - placing the LPSU ontop of a thick slab of ploystyrene has made a positive difference - therefore a properly designed solution should benefit far greater
Chris
No Nonsense here - http://en.wikipedia.org/wiki/Equal-loudness_contour
Hard knee house curve is based on solid facts - humans dont hear bass in a linear fashion, all say they want a flat freq reponse but the reality is the deeper the bass the more volume is needed for it be audible at the same volume. A flat freq response is not actually flat in how you hear it.
Therefore a curved bass setup actually works better - and followinng the advice you set it up to your ears
The hard knee house curve addresses the issue of bloated bass caused by a standard house curve - once you have your system setup like this I doubt you could ever go back as you could hear where the bass is severly lacking.
Covenanter said:ellisdj said:Covenanter said:ellisdj said:ellisdj said:Its the Linear Power Supply powering part of the audio Pc thats my point of initial interest - placing the LPSU ontop of a thick slab of ploystyrene has made a positive difference - therefore a properly designed solution should benefit far greater
Chris
I don't know what to say to you!
Chris
ellisdj said:Bloody snake oil brigade
ellisdj said:Lindsay T - just because you put your.... (tuncated)
