- Aug 10, 2019
- 2,556
- 4
- 0
I've read elsewhere that many other Samsung TV owners are experiencing the same problem; since the last firmware upgrade the iPlayer is now missing the 'play' button. i.e. nobody can use the iPlayer anymore!
I've contacted Samsung and they've basically shurgged their shoulders and said it's the BBC's fault and they need to fix it. However, they did say the BBC are aware of the problem and are working on a fix. Still waiting to hear back from the BBC to see if that is actually the case.
I've only just bought my set, so haven't even used the iPlayer yet, almost sent it back as faulty before doing a quick google
Has anyone else got further info or worked out a 'work around'?
Thanks,
Thanks,
