So it's taken over 2.5 hours to download and install, but we're finally there. Instant impression - is it just me, or does it look a little shinier? 🙂
Time to have a play...
Cofnchtr said:Edit: iPad is now downloading the iOS5 update. Would have thought one download would have been sufficient for all idevices?
Paul Hobbs said:Cofnchtr said:Edit: iPad is now downloading the iOS5 update. Would have thought one download would have been sufficient for all idevices?
There is a lot of variation in functionality between the models (there is a different install for iPad and iPad2 for instance). They have seperate installers to keep the build as lean and fast as possible.
Cofnchtr said:Can't move the newstand to another folder though 😱(
Cofnchtr said:Have synced via wi-fi but itunes keeps starting itself on the PC - possibly because I have enabled wifi sync?
professorhat said:Need a favour guys as I cannot get Wifi syncing to work. In iTunes, when you're iDevice is connected, do you see the following on the Summary tab? (click on pics for full size version)
Cos this ain't what I see. I get
Have been through troubleshooting guide and getting nowhere, so just want to check and make sure other people are seeing what I'm not!
professorhat said:Some further digging has revealed the possibility Wifi sync only works on OS X 10.6.8 and above - a little annoying as I'm stuck on 10.5.8 on my PowerPC Mac...
I've not confirmed it yet, but this is certainly looking to be the most likely cause.
DrizztDan said:error 3200,
