MajorFubar
- Mar 3, 2010
- 690
- 9
- 0
BigH said:drummerman said:I use profigold Oxypure. Fantastic.
Go compare.
Its too noisy
They say it works well with Welsh male opera singers.
Go compare.
Its too noisy
Go compare.
Its too noisy
keeper of the quays said:Cables do make a difference..so all the wise and noble gentleman above who have kindly showered their years of discerning listening into cables make no difference! Are any of them using freebie cables? Why would anyone have expensive equipment and join it up with freebie interconnects? It frankly ludicrous!
Al ears said:Alberich said:MajorFubar said:TrevC said:Use the freebies. No outlay and identical sound!
'Non believers' like you and I are probably better sitting-out these type of threads. I've found that generally people don't want to be told they're mistaken, unless they specifically ask 'is this a load of tripe or is there something to it'. While we might be trying with our best intentions to stop them making [sometimes very expensive] wasted purchases on the assumption that they genuinely don't understand, I've learned it's not the message they want to hear and it rubs their fur the wrong way, no matter how you say it.
That said, for £18...I'd give it a shot, even if it's just buying you better build than the standard cables.
Well then why don't you?
Why don't you stay away from threads that discuss something you obviously have no time for, instead of trying to patronise those involved with comments like 'rub their fur the wrong way'
It seems a benign and freindly discussion between people about cables rubs your fur the wrong way.
You honestly think this forum is a good place for a friendly discussion about cables? Perhaps if you searched previous threads you will see you've come to the wrong place. 🙂
MajorFubar said:Alberich said:Don't become professionally offended just because I reminded you of your lack of impulse control. Your genuinely cracking me up here.
Think you need to ask the nurse to increase your medication. Let the record show that the first person to start an argument on this thread is you. You decided you were taking offence to a reply I made directly to another member, on a thread which upto that point you hadn't even contributed to. You had the right to ignore it, but no, you had to plough in and make more of it than was ever intended. Get over your big self.
EDIT: Oh and while we're at it, on my post which offended your soul so much, you may notice I recommended he tried the £18 cable. It could be a good buy. But of course you don't mention that in your criticism because it doesn't suit your agenda of depicting me as the thread's trouble maker.
TrevC said:BigH said:drummerman said:I use profigold Oxypure. Fantastic.
Go compare.
Its too noisy
I prefer meerkats.
MajorFubar said:BigH said:drummerman said:I use profigold Oxypure. Fantastic.
Go compare.
Its too noisy
If one doesn't think it makes a difference then that's fine! If these people with their fine hifi use freebie interconnects? That's fine too..they can do whatever they want..its a pity though that they are not getting the best out of the equipment due to using freebie interconnects..just gives me the pip that they have the audacity to suggest us who know that cables make a difference are misled?TomSawyer said:Probably going to regret putting my head above the parapet, but surely there has to be an improvement in sound by using better quality interconnects? Don't get me wrong, I'm not talking about unobtainium wrapped around graphene nanotube sound pipes but the interconnect becomes part of the signal path at relatively low signal level and I would have thought that decent quality copper, well terminated would yield some benefit over shoe-lace freebies with moulded plugs?
I've always spent about £20 on an RCA cable for that reason. I realise the members that have been here a while will understand the debate that has previously taken place but I have to say searching previous posts isn't easy and I think it would be genuinely interesting to understand.
The debate so far has a touch of Life of Brian about it.*biggrin*
keeper of the quays said:If one doesn't think it makes a difference then that's fine! If these people with their fine hifi use freebie interconnects? That's fine too..they can do whatever they want..its a pity though that they are not getting the best out of the equipment due to using freebie interconnects..just gives me the pip that they have the audacity to suggest us who know that cables make a difference are misled?TomSawyer said:Probably going to regret putting my head above the parapet, but surely there has to be an improvement in sound by using better quality interconnects? Don't get me wrong, I'm not talking about unobtainium wrapped around graphene nanotube sound pipes but the interconnect becomes part of the signal path at relatively low signal level and I would have thought that decent quality copper, well terminated would yield some benefit over shoe-lace freebies with moulded plugs?
so if I take off my lfd solid silver handmade variable thickness silver wire interconnects and replace them with a pair of freebie interconnects or a £20 puresonic or Belkin interconnect it's going to sound exactly the same? I have a Belkin interconnect and comparing it with my vdh is huge difference! By all means come and listen..judge for yourself no blind test required! I would much rather us gullible fellows spend our money on our wives, cars etc than bloody interconnects unfortunately us gullible ones can't...we want to get the best out of our equipment thus respecting the skills of the people who made the stuff in the first place..who in this forum has good equipment with freebie cables or freebie interconnects?BigH said:keeper of the quays said:If one doesn't think it makes a difference then that's fine! If these people with their fine hifi use freebie interconnects? That's fine too..they can do whatever they want..its a pity though that they are not getting the best out of the equipment due to using freebie interconnects..just gives me the pip that they have the audacity to suggest us who know that cables make a difference are misled?TomSawyer said:Probably going to regret putting my head above the parapet, but surely there has to be an improvement in sound by using better quality interconnects? Don't get me wrong, I'm not talking about unobtainium wrapped around graphene nanotube sound pipes but the interconnect becomes part of the signal path at relatively low signal level and I would have thought that decent quality copper, well terminated would yield some benefit over shoe-lace freebies with moulded plugs?
You have done double blind tests?
In blind tests many people can't hear the difference, some can but some of those say its because they have been trained, so they are listening for certain sounds in the music not listening to the music as such. Many in the audio industry don't believe it or say the differences are small, read Roger Russell's article. A lot of people are mislead by manufacturers adverts and claims, we are gullible thats why advertising works. When they test medicine they have a placebo, its funny the people on the placebo often have positive results even though they were not taking any medicine. I did a test once, sighted, I could pick one that sounded better, then it went blind, well could I hear a difference, no. So anyone buying cables should do a blind test, double blind is better.
keeper of the quays said:so if I take off my lfd solid silver handmade variable thickness silver wire interconnects and replace them with a pair of freebie interconnects or a £20 puresonic or Belkin interconnect it's going to sound exactly the same? I have a Belkin interconnect and comparing it with my vdh is huge difference! By all means come and listen..judge for yourself no blind test required! I would much rather us gullible fellows spend our money on our wives, cars etc than bloody interconnects unfortunately us gullible ones can't...we want to get the best out of our equipment thus respecting the skills of the people who made the stuff in the first place..who in this forum has good equipment with freebie cables or freebie interconnects?BigH said:keeper of the quays said:If one doesn't think it makes a difference then that's fine! If these people with their fine hifi use freebie interconnects? That's fine too..they can do whatever they want..its a pity though that they are not getting the best out of the equipment due to using freebie interconnects..just gives me the pip that they have the audacity to suggest us who know that cables make a difference are misled?TomSawyer said:Probably going to regret putting my head above the parapet, but surely there has to be an improvement in sound by using better quality interconnects? Don't get me wrong, I'm not talking about unobtainium wrapped around graphene nanotube sound pipes but the interconnect becomes part of the signal path at relatively low signal level and I would have thought that decent quality copper, well terminated would yield some benefit over shoe-lace freebies with moulded plugs?
TrevC said:... I refer you to this scientific blind test. http://matrixhifi.com/ENG_contenedor_ppec.htm
chebby said:TrevC said:... I refer you to this scientific blind test. http://matrixhifi.com/ENG_contenedor_ppec.htm
Not that old chestnut? Please get a new test (or at least a different one) to link to.
I basically agree with you but I still groan a bit every time I see that bit of hi-fi 'archaeology' dragged up again.
TrevC said:keeper of the quays said:so if I take off my lfd solid silver handmade variable thickness silver wire interconnects and replace them with a pair of freebie interconnects or a £20 puresonic or Belkin interconnect it's going to sound exactly the same? I have a Belkin interconnect and comparing it with my vdh is huge difference! By all means come and listen..judge for yourself no blind test required! I would much rather us gullible fellows spend our money on our wives, cars etc than bloody interconnects unfortunately us gullible ones can't...we want to get the best out of our equipment thus respecting the skills of the people who made the stuff in the first place..who in this forum has good equipment with freebie cables or freebie interconnects?BigH said:keeper of the quays said:If one doesn't think it makes a difference then that's fine! If these people with their fine hifi use freebie interconnects? That's fine too..they can do whatever they want..its a pity though that they are not getting the best out of the equipment due to using freebie interconnects..just gives me the pip that they have the audacity to suggest us who know that cables make a difference are misled?TomSawyer said:Probably going to regret putting my head above the parapet, but surely there has to be an improvement in sound by using better quality interconnects? Don't get me wrong, I'm not talking about unobtainium wrapped around graphene nanotube sound pipes but the interconnect becomes part of the signal path at relatively low signal level and I would have thought that decent quality copper, well terminated would yield some benefit over shoe-lace freebies with moulded plugs?
You are imagining the differences you hear. It's as simple as that. I refer you to this scientific blind test. http://matrixhifi.com/ENG_contenedor_ppec.htm
ellisdj said:TrevC said:keeper of the quays said:so if I take off my lfd solid silver handmade variable thickness silver wire interconnects and replace them with a pair of freebie interconnects or a £20 puresonic or Belkin interconnect it's going to sound exactly the same? I have a Belkin interconnect and comparing it with my vdh is huge difference! By all means come and listen..judge for yourself no blind test required! I would much rather us gullible fellows spend our money on our wives, cars etc than bloody interconnects unfortunately us gullible ones can't...we want to get the best out of our equipment thus respecting the skills of the people who made the stuff in the first place..who in this forum has good equipment with freebie cables or freebie interconnects?BigH said:keeper of the quays said:If one doesn't think it makes a difference then that's fine! If these people with their fine hifi use freebie interconnects? That's fine too..they can do whatever they want..its a pity though that they are not getting the best out of the equipment due to using freebie interconnects..just gives me the pip that they have the audacity to suggest us who know that cables make a difference are misled?TomSawyer said:Probably going to regret putting my head above the parapet, but surely there has to be an improvement in sound by using better quality interconnects? Don't get me wrong, I'm not talking about unobtainium wrapped around graphene nanotube sound pipes but the interconnect becomes part of the signal path at relatively low signal level and I would have thought that decent quality copper, well terminated would yield some benefit over shoe-lace freebies with moulded plugs?
Look at the power wiring for that blind test - no wonder they couldnt hear the differences - all the system were being strangled by being powered off that cheap and nasty extension lead - and they all powered into the same block so the noise from the crappier components is polluting the better ones.
All that effort, putting up the acoustic treatments (in the wrong place) and they missed something important like that - shows the effect of poor mains quality more than anything else.
ellisdj said:Mains is one of the largest influencer on sound quality - much more so than interconnects and speakers, which is crazy considering its not even in the audio signal chain but its how it is if you want really good sound.
Certain aspects are system levellers - room acoutics is the first one. Mains quality is the second - it hinders a system ability to produce its full scale of sound and the system ability for the sound to be truly free of the speakers.
BigH said:ellisdj said:Mains is one of the largest influencer on sound quality - much more so than interconnects and speakers, which is crazy considering its not even in the audio signal chain but its how it is if you want really good sound.
http://www.hifiwigwam.com/showthread.php?654-The-Great-Cable-Debate&highlight=blind+test
Well in that test they did not think so.
ellisdj said:TrevC said:You talk from your bottom
Talking from it to one
