Integrated amp recommendations?
Hey guys,
I'm currently in the market for a new (integrated) amplifier to power my Focal 165 K2Ps ( http://www.focal-fr.com/catalogue-front/produit.php?langue=EN&idArbo=14&idProduit=97 ) and have short-listed a few models, based on online research:
http://www.pliniusaudio.nzld.com/products/hautonga.asp
http://www.leema-acoustics.com/shop/component/amplifiers/pyxis
http://www.leema-acoustics.com/shop/component/amplifiers/tucana
http://uk.yamaha.com/en/products/audio-visual/hifi-components/amps/a-s500___g/?mode=model
Are there any additional models I should be considering? Not bothered about budget at this stage.
Look forward to reading your suggestions!
Thanks in advance,
CnoEvil
556
14
If Focal car speakers sound like their regular ones, then try with Class A.... SS (eg. Sugden as suggested) or tubes (like Pure Sound or Ayon).
I've also heard Focal sound well with Electrocompaniet.
Cno
CnoEvil said:
If Focal car speakers sound like their regular ones, then try with Class A.... SS (eg. Sugden as suggested) or tubes (like Pure Sound or Ayon). I've also heard Focal sound well with Electrocompaniet. Cno
am i missing something here Cno? i mean they are car speakers? right?
CnoEvil
556
14
Max, you're not missing something.
I'm assuming he has put them in some kind of cabinet. Unless he has done this very effectively, then good amplification could be overkill.
We hopefully will be enlightened shortly.
Hi all,
Indeed, they are car speakers. And indeed, I do know a little about box design/build
LINK REMOVED - House Rules
