plastic penguin
Vladimir said:Its all WHF fault, they should stop nicking your syntax™ for their magazine. Cuh! The nerve of them.
Easy...
pmconcierge said:Any advice for b&w cm7's? I would like your opinion. Sorry for jumping on the thread but I think you could help!
Vladimir said:Me and my big mouth.![]()
Vladimir said:Agreed. Too much coffee too late in the evening for me.
stevebrock said:plastic penguin said:Earendil said:Man you are getting me worked up on the A-S1000, it really looks like it would rock. It is a bit out of my budget though, I suppose I could make the effort if I had to, you guys really think it is worth the price premium over the A-S500? This one seems like a good buy too.
The A-S500 review points towards a bright presentation, so unless you have a well-damped room I would still look at Marantz or Creek as a better match for MAs hard domed tweeter.
I suggest he OP demos for himself - I dont know how you get to the assumption how this amp/speaker will sound!
OP - please go and demo for yourself prefably in your listening room (find a good dealer)
PP your posts sound like the syntax from many what hifi reviews - ie bollox
Earendil said:stevebrock said:plastic penguin said:Earendil said:Man you are getting me worked up on the A-S1000, it really looks like it would rock. It is a bit out of my budget though, I suppose I could make the effort if I had to, you guys really think it is worth the price premium over the A-S500? This one seems like a good buy too.
I know that the best would be for me to demo first, but unluckily the only demoing options I have (that I know of) are a few onkyos (TX-8030, TX-8050) and a couple of 5.1 and 7.1 Yamahas and Marantz I'm not really interested in. So it will most likely be a blind buy and that is why I appreciate all the help I can get.
So far I really liking what I have read on the Yamaha A-S1000, but the more opinions I get, the better!
Vladimir said:There really isn't that much sonic difference between well made tube and SS amps.
plastic penguin said:Vladimir said:There really isn't that much sonic difference between well made tube and SS amps.
There is... don't mistake "difference" with better.
Vladimir said:Flea watt SETs sure sound different but I consider those more of a fetish and not proper amps.
floyd droid said:plastic penguin said:Vladimir said:There really isn't that much sonic difference between well made tube and SS amps.
Aye, and dont mistake better with ,erm , better. All down to personal taste isnt it.
PP , when your new best mate of all time was going through his transition period ( remember ,as you obv do , that I'm a valve nut ) , I never once told him its the only way to go. Twas a case of 'try one or two cos valves aint for everyone '.
Vladimir said:Not because they are valve amps but because they are flea watt. 😛oke:
pmconcierge said:Best amp for cm7's. I have been running them as fronts in an av set up with a yamaha av amp and although movies even streamed sound great, music ips decidedly lacklustre. Biggest problems are a lack of finesse with the high frequencies with a little bit more sibliance in vocals than I would like. I am just using appletv for music at the moment but will be considering a dac to hook up my mac in the future. If the amp has a dac, all the better. Budget is a b@£&h! Am interested in your opinion on the lower end amps in marantz etc, but also in a more 'buy it, forget about it for 10 years' purchase so budget is really £250-£1200! At least there should be a few options! Using the amp to power the fronts in an av set up is also an important factor for flexibility purposes. At present the system is in a 15ftx15 room though may move into a 12x12 in the future. Hope this makes it easier not harder for your valued opinion. :cheers:
Vladimir said:IME the best amp for B&W is a very powerful one, both watts and current drive. Brand and badge unimportant, the speakers will dominate with their sonic signature. I'd avoid small integrateds like Naim, Creek, Rega.
Vladimir said:I mean I would focus more on performance per price ratio. Rotel RC1070/RB1070 second hand would do the trick nicely I think. I didn't catch what would be the budget limit but even better if its new Rotel RC1580/RB1582.
I think the synergy between B&W and Rotel comes from the lack of presence (-3db) in the upper midrange on B&Ws due to the kevlar and the dry bright caracter of the Rotel in that region coming from the high power, current and damping factor. Incedently (or not) Rotel's "flaws" are what B&W needs to flatten out the FR and sound to their best and under control. It is a marriage of flaws and strengths complementing each other.
B&W and Rotel are a safe bet for people new to the hobby. I personally like Hegel, EC and Roksan better with B&W.
