- Aug 10, 2019
- 2,556
- 5
- 0
Oh dear not another cable test... A friend dropped around with some cables which included a 1.5m Black Rhioduim Jazz power cable. I wasn’t intending to do “serious” testing but just to mess around. Anyway, the Black Rhodium (BR) was plugged in and I thought I could hear a noticeable difference in soundstage and clarity immediately. I was sure I could, as was my friend after changing to and from the standard cable that came with my Kandy. After a few bevies I managed to persuade my significant other to participate in a test but only on the premise that we played Dolly Parton. So, I devised a quick test whereby we would listen 20 times to “Jolene”. Oh dear, but quite a moving song half drunk actually! She marked on paper 1 to 20 and underneath a “1” or “0” denoting the cable of choice but making sure each cable was used ten times as randomly as she felt fit. We had to decide which cable sounded better during the 20 playbacks and marked on separate sheets G for Black Rhodium or B the standard. The presumption was that the BR sounded better as I was sure it was from previous listenings. We were quite unobservant whilst she fiddled changing the cables… Once the test had finished I was quite sure I knew which cable was the BR, whilst my friend thought he could tell, but wasn’t as sure. Results: I got the BR correct 8 times out of 20. My friend was correct 11 times. Conclusion: Black Rhodium made no difference in comparison to the sound from the standard cable on my Kandy set up, at least there is little statistical probability in the “results” we obtained. The small sample and scope of test might have limited an accurate measurement. Laphroaig and Budvar might make your lugs hear mush irrespective of choice of cable… Recommendations: Try something similar if your bored or can be bothered…
