That one was a zoom in from a long distance on Sky!ellisdj said:Was more lack detail in whites I was on about on right (his left) side face
What made me think maybe sky compression Or just the distance from the screen
When there's a lot of black, the camera will try to overexpose whites, and when there's lot of white, the camera will underexpose blacks.ellisdj said:Was more lack detail in whites I was on about on right (his left) side face
bigboss said:Phone cameras aren't good at showing blacks properly. Their sensors are too small, and the camera compensates for the lighter background.
Yep, they look much better on Flickr on even my iPad Pro.buzz_lightclick said:bigboss said:Phone cameras aren't good at showing blacks properly. Their sensors are too small, and the camera compensates for the lighter background.
I believe Gel uses an iPad camera, (probably the one on his iPad Pro), but I guess your point still stands.
I find it very hard to get an impression of his TV from the squashed photos on this forum, I would prefer if he uploaded some pics to Flickr or another similar website and then posted a link.
davidvann said:hi buzz light-click have you tweaked your voltages on your krp .
gel said:Yep, they look much better on Flickr on even my iPad Pro.
Will do - cheers!Paul. said:gel said:Yep, they look much better on Flickr on even my iPad Pro.
have a look at the sticky for uploading photos to the forum, you can make your photos clickable so they go full screen in Flickr 🙂
it just seems a lot different. Perhaps it's the size? Everyone who sees it says it's amazing though, I think it's taking a while for me to get used to it though. LG's do seem to be not so good at being setup though.ellisdj said:Gel mate that TV is really good and I dare say setup properly. You have probably got used to looking at in correctly.
Its an LG panel for starters how can it be that much different
gel said:I can't quite work out if my TV is really really good or not so good?
