[quote user="al7478"]OK, their keyboards and mice look a bit pricey, but if i could buy any old usb one (my current one isnt) and connect it maybe thats ok.[/quote]
Any old USB keyboard and mouse will do.
[quote user="al7478"]However, am i right in thinking that the software you refer to would allow me to make playlists for it using my pc keyboard and mouse? Would this require a network connection from mac mini to pc (or an ethernet connection)?[/quote]
We're getting into territory I'm unfamiliar with now, so I need to be careful! However, using a normal USB keyboard and mouse, you operate the Mac Mini like any other Mac. So you could rip CDs, make playlists etc. just as you would on a standard Mac. However, I'm not sure exactly how Front Row operates (as my Mini Mac was one of the original beasts before Front Row came with it) - therefore it may not pick these up from whichever bit of software you choose to manage your music. I know there are alternatives around though, one I know of is
equinix MediaCentral which is an alternative to Front Row that may fulfill these needs.
Basically, you're limited by whatever software operates on Mac OS X. When it comes to music, this is a lot of choice.
[quote user="david1997"]If you are reluctant to give up your PC then VMware Fusion is a nifty piece of software that will allow you to run Vista, XP Linux or whatever on your Mac as a 'guest' O/S.[/quote]
Yup, I use VMware's products heavily in my professional capacity (I'm a VCP), and I can confirm their products are excellent and work just as they say they do, so this is a good alternative for running both a PC and a Mac. I'm not sure it's something you would want to do on the Mini Mac though, since this isn't really designed for that use and may well run slow (especially if you're trying to run Vista on it!).
