How to unlock Marantz PM7001
Hi FMs,
I recently bought a Marantz PM7001 integrated amplifier second-hand. It did not come with a remote control, so I ordered an original spare. The problem I have is that the amplier input is restricted to the CD function; the tuner, aux, phono and everything else is pretty much "locked". Does anybody know how to go about unlocking the amp? Is there a certain RC key combination or some other method that can be used? Anyone have any clue, please let me know.
Thanks & Regards,
JS
Jithu Sudhakar said:
Hi FMs,
Thanks & Regards,
JS
As far as I am aware the buttons for source selection on the remote will only work if you have Marantz equipment attached to the amp. There is no way to lock-out selective sources.
Can you switch sources via the source select knob on the amp?
I tried switching the source by turning the source-selection knob but it doesn't do anything. Usually, only the selected input lights up on the indicator strip. In my case, when I switch on the amp, all the lights come on, even the mute light, and stay on irrespective of whether I turn the selection knob or press the corresponding button on the rc. I can't even switch on or off the amp using the rc. But when I tested the rc against another marantz i have, it worked perfectly.
TrevC
Now you know why it was sold.
spiny norman
293
It's clearly faulty and needs to be repaired. Unless It was sold as 'spares or repair' I'd take/send it back and get a refund.
Ditto.
