How to set a 1050TI video card to 24P (progressive)
i have video card 1050TI
the video card driver has a choice of data rate from 23 Hz to 60 Hz
But can't aim for 24 Hz progressive like in AMD CARD ?
the film looks bad and pictures look like the movie from the 1920s / Not smooth
after each image, there is a space that destroys viewing
I have samsung tv 65" 4k
so i need to work with 3820X2160 24p
I found a similar link but to the 1080P resolution
How to Achieve Perfect 23.976Hz 24p with NVidia
Hi guyz, I had found this solution for quite some time and it works really well with reclock. NVidia 24p is 24Hz. But ideally you will need 23.976 HZ to have perfectly smooth panning. It is quite simple to achieve. 1. Go to Nvidia Control Panel 2. Change the Resolution to 23 HZ 3. Create...
forum.redfox.bz
