If you ever spot Spam (either in the forums, or received via forum direct message) please use the Report button at the bottom of each post to make sure a Moderator can handle it quickly. Thanks for your help in keeping things running smoothly!
hi everyone just got denon 37 for my son and think it sounds pretty good, iam now looking to buy stereo system for myself and wanted to know how much i would need to spend to get a marked improvment in sound, thanks
This depends of course on which speakers you have but I would say about £600.That would be for an amp and a CD-player. Don't know if you need a tuner, if so an extra £100 would do the trick.
Thanks, speakers are eltax monitor111 which are not expensive, i was thinking of nad cd and amp (about £400 for both) mezzo 2 speakers, do you think this would be a good improvment.
hi daveh , just seen you got some Roksan 111 kit , is it as good as the reviews say, i might wait a bit and get them both( cd/ amp) or really go mad and get k2, but i will have to sneak them in the house,
