With regards to a DVD's soundtrack. What are the lowest frequencies that are sent out to the 5 main channels. I know you set the reciever to 60-80Hz etc. Depending on the speakers you have.
i.e. sattelite speakers may need a higher crossover setting.
But if you have floorstanders that go as low as 40Hz. Is there even a signal from the DVD that goes that low to Front L & R. Is the .1 in 5.1 dictated by the user manualy or by the actual DVD disc.
Thanks.
Thanks.
