Cheers David. I will have a months viewing and then quit.David@FrankHarvey said:You can watch as many films as you like as long as you're paying them monthly - couldn't tell you the current prices.
Ah cheers, how do I go about getting it? I have Netflix on my remote control but that's all I know. Do you pay for it through Amazon or something? Cheers!Paul. said:I would pay the top teir to make sure you get 4K content, think it's £8.99 per month. A month should give you time to watch daredevil season one and two as well as Jessica Jones
although daredevil is not HDR, it is very very contrasty. Lots of dark scenes with high peak luminance in the highlights, should look fab on your TVs.
Ah cheers, very helpful, thanks.jog3004 said:You can subscribe through iTunes or direct to Netflix. The normal full had service is £6.99, the 4K version is, I think, £8.99 a month. I'm not sure if you can get the latter via iTunes. Be aware that for 4K streaming Netflix recommends an internet speed of about 24-25mbps, otherwise you supposedly get a lot of buffering.
Okay, cheers.jog3004 said:If you've received confirmation email that you've registered, go onto Netflix via smart functions of your tv, then choose already registered or it may be log in ( can't remember exactly), then it'll ask for the email you've registered with, enter that, then it'll ask for your password, enter & that should take you to the home page.
Troll alert What Hifi and reported.nugget2014 said:gel said:I can't get my TV to connect with it.
what a shame.
Ah cheers mate. Thanks.jog3004 said:Try downloading the app onto your iPad & see if it works via the app. If it does then you need to check your tv manual, although on my to its simply via highlighting Netflix app & pressing ok. If the iPad app doesn't work, it may suggest you haven't registered fully, if so, contact Netflix, they're friendly & helpful.
Is DareDevil 4K?Paul. said:I would pay the top teir to make sure you get 4K content, think it's £8.99 per month. A month should give you time to watch daredevil season one and two as well as Jessica Jones
Nope, I didn't sign up for 4K, didn't see where I could? Connected my TV to the wi fi internet. Not sure if broadband can cope with it but it's working on the iPad.richardw42 said:Have you connected your tv to your router Via wi fi or Ethernet ?
Did you sign up for 4K. Can your broadband cope with that ?
i am using a small manual that came with the TV, I will try downloading the longer version too. Cheers.MajorFubar said:I don't want to come across as condascending but someone's got to ask...have you ever tried downloading the manual (if it didn't come with a printed manual) seeing as it's your TV and none of us as far as I'm aware have the same model? How can members possibly tell you how to work your TV other than offer broadbrush guesswork based on how ours work.
Definitely worth a shot...it will go into all kinds of detail that we can only guess at.gel said:i am using a small manual that came with the TV, I will try downloading the longer version too. Cheers.
Is your TV connected to the Internet?gel said:I can't get my TV to connect with it.
Yep. I have already got a firmware upgrade.bigboss said:Is your TV connected to the Internet?gel said:I can't get my TV to connect with it.
