mike0619:
I have just bought the panasonic 50"V10 but can't connect it to network. Tried just plugging blue cable from pc into back of tv and didn't work. Pc is near tv but Virgin netgear wireless router in front of the house. Any idea if Wireless Ethernet bridge will work or
Belkin 802.11g Wireless G Gaming Adapter will work as alot cheaper than the bridge
regards
Is the PC connected wirelessly to the router? Or is it connected via ethernet cable?
If the PC is connected via etehrnet cable to the router, and it's close enough to the TV, you could get a small network switch, which you can then plug all three devices (TV, PC and wireless router) into.
Attempting to connect the TV wirelessly may result in difficulty, such as not being able to enter the wireless encryption key etc.
If the PC is connected wirelessly, you could possibly configure that as a bridge / router to allow the TV access to the internet - however you will need some detailed PC knowledge to do that.
Tony.
