Given the apparent popularity of my explanation of why a star connected mains strip can't possibly make any difference to sound quality, I thought I would extend my occasional series to Power Supplies. Given the breadth of the subject, this may have to be a multi part posting.
Linear audio amplifiers of the type found in home hifi need a stable and clean DC supply to operate. The problem is that most amplifiers are mains powered, and mains is AC. Mains is too high a voltage to be useful for home hifi, and also has the real possibility of killing you.
So, in no particular order, a power supply has to:
1. Isolate the equipment from the mains
2. Drop the mains voltage to a suitable level
3. Turn the AC into stable DC
4. Filter out any noise
As any follower of Nikola Tesla will know, he was the proponent of the 'multi phase AC system' which was in competition with Edison's DC system - the so called war of the currents. For various technical reasons, home mains AC supply isn't multi phase, it is single phase. For those who can remember their physics, a single phase mains waveform displayed on a 'scope looks just like a simple sine wave (because it is).
Now this is where the first 'inconvenient truth' shows up for the mains cable brigade. That mains sinewave crosses through zero twice every mains cycle. At that point, there is no power at all coming down the mains wire - if you were quick enough with a voltmeter, and could connect and disconnect it just at the zero crossing point, it would measure ZERO volts.
Hmmn. So twice every mains cycle (100 times per second), there is a period of time where NO power comes down the mains lead at all. What if (Sir) RIngo Starr was bashing his cymbal at just the point the mains crossed zero - would there be silence out of the speaker? Experience would indicate that you can still hear the cymbal, so either (Sir) Ringo has excellent timing and misses the zero crossing point, or there is something else going on.
I will explain in the next post what is going on, but the first question for the cable brigade is if there are significant periods of time when the cable is not conducting at all, how can it possibly effect transient response during the period there is no power coming down the cable?
