hooray - success!
Craig M.
127
i think the cat is trying to hypnotise me
hmm, they haven't come out very big. i'm new to flickr, does anyone know how i can get a bigger pic without ruining the quality?
edit: added new amp pics on page 2.
Depends. The links you;ve entered all have height and width set, presumably by Flickr, but if you go in and edit the html you may be able to change the size.
yes, flickr seems to have set the size but the original photo was huge.
it looks like the way you have done it is by stretching the picture, i meant how do i get more of the original pixels - if that makes sense?
edit: to answer your earlier question about usb and optical on the dm, i checked again the other night (1st time with these speakers) and optical is definitely better.
Don't know flickr's naming conventions, but there will certainly be links to different-sized versions - if you take a look at the link for that jpg, there's an '_m' at the end - if you change it to '_s' you get a small version. You'd expect 'l' ('L'), therefore, to give you a large one, but it doesn't - take a look at the photos on flickr yourself and see if you can work out where the big one is. Note that you'd probably need to size larger photos *down* when inserting the html (max width 400).
Failing all that, use photobucket, which definitely stores larger images.
Very nice set up there Craig. I reckon those ATCs would be the right size for my new lounge. Hmmm. Our cat does that to me all the time, always ends up with a long hifi session...
cheers igg, in this case she was saying "play with me or i'll attack your foot!"
the tasteful leopard print thing behind the left speaker is a "catnip scented play tunnel", things get a bit "interesting" when she's been in there! she did wall of death round the room just after before mauling my foot... still, makes a change from her trying to get milk out of me!
Good grief, sounds just like my cat! I had to throw the tunnel because I can't bear the noise of a carrier bag being scrunched up all night. Still, she's a good lap warmer for listening sessions.
Nice looking setup fella and a great cat pic too!
One of ours loves to listen to the cricket...
Craig M.:
Hi Craig M.
Your current system looks great.
Thanks for your support.
All the best
Rick @ Musicraft
Sweet setup Craig. You know a lot of people knock the way the ATCs look, but I'd say your 19s look quite smart on those stands. I rather like them. I wish I could hear them...
thanks for the comments. the amp and source will change soon so i'll stick some pictures up, or i might wait until we've decorated. the other half has consented to some room treatment "as long as it looks ok", i'm just thinking of a few panels to cut down on slap echo. i'll let you know if i ever find some that passes muster....
idc:Very smart and stylish. I am sure your speakers benefit from the space they are in.
thanks, i think the lack of side walls means i don't have anything interfering with the sound although i'm pretty sure the atc's wouldn't make too much fuss wherever i put them, they just don't seem to react with the room at all. my old dyn's on the other hand, it took me about 4months before i really found their best position, just a few inches out or a change in toe-in and they didn't sound so good.
some pics of the new amp. bought from the famous "Rick@Musicraft", i am absolutely delighted with it.
in fact, you could say i am over the moon......
haha, can you tell 2 pics were taken in natural light and 2 under tungstens?
4286249692
If I had a spare couple of k to spend on an amp...
...superb looking stuff Craig. Surprised you showed the Moon the door so quickly.
cheers iggle, i suspect that joel would cream himself if he heard the moon but this is a much better fit for me. it really is a perfect match for my speakers.
should have the new dac in about a week or so.
thanks, i have to be careful taking pics that i don't get too anal about it - otherwise the g/f will come home and find i've turned the front room into a studio with lights all over the place and me covered in sweat! in fact i'm getting irritated already just looking at 2 of those pics
still, that anal quality means i don't mind a bit of time with some pledge multi-surface wipes
