Home Cinema Setup Issue.....
ukgthor
29
I've recently had the following system setup for me, however I can only get sound from my SKY HD box and not picture. Can anyone tell me what the potential issue could be (I've checked that the HDMI cables are in place and connected correctly) ?
System:
Pioneer KRP-500a
Pioneer SC-LX81
Pioneer BDP-LX71
B&W MT-30 with PV1 Sub
Might help if you told us HOW the Sky box was connected to your gear.
Be interested to know what it all sounds like though, that's the setup I'm thinking about as well.
You will need an optical or digi-coax cable for DD5.1 and change the sound settings to "DOLBY D" in the sky+HD sound settings menu. Have you assigned the audio input on the amp to the same as the HDMI so that the picture and audio match?
Have you tried connecting the sky box directly to the tv? If that works, then there is probably a set up option on the amp to tell it to output HDMI.
Does the amp setup menu appear on the TV?
the_lhc:Which is all well and good but doesn't explain why he's not getting a PICTURE.
And what exactly is the point in your post? At least I'm trying to help! Jeez, some people.....
Yes, so am I trying to help, but the OP is complaining he isn't getting a picture, so what use is telling him to use an optical cable for DD5.1?
It's all irrelevant until he tells us how everything is connected anyway, so there's no point us arguing about it, shake?
