- Aug 10, 2019
- 2,556
- 5
- 0
System
JVC HD1 Projector
Yamaha RXV 2500 AV Amp
Sony BDP550 BR Player
Denon 3930 DVD
Kef Q7 Fronts
Kef Q9C Center
Kef Q Rears and Surrounds
Paradigm PS1000 Sub
Ive just submitted my plans for my new HT room that is to be built over my garage, this explains the size of 9m long x 2.5m wide.
The sitting position will be 4m away from the screen.
My question relates to speaker position, fronts and centre no problems, surrounds on either side of the sitting position, my problem is the rears, do I position them on the back wall which will be another 5m away or do I bring them forward into the room.
My thoughts were to postion the rears on the walls 2m back from the sitting position angled inwards towards the seats.
Also my current screen is 2m wide which will take up most of the wall width which means my Q7s will be in the corners, would I be better with a smaller screen so I can pull the speakers out of the corners a bit.
Regards
John
JVC HD1 Projector
Denon 3930 DVD
Kef Q7 Fronts
Kef Q9C Center
Paradigm PS1000 Sub
Regards
John
