stereoman said:
insider9 said:
stereoman said:
Leave acoustics, jumper links, positioning alone. They do not help drastically. They will not change your sound to the point of liking it.
I either didn't get that bit it or simply can't agree.
Great speakers poorly positioned can sound worse than mediocre speakers optimally placed. Differences can be significant and make you like/dislike speakers.
That is the reason why I started this thread. In my personal experience, in your room, the speakers that you are dissatisfied with will never ever change their sound character no matter how you much you gonna try to position them in the best place. You can only improve and apply this rule to already good sounding speakers by finding better acoustics. I had a couple of good and bad speakers, the bad speakers could never ever be improved by room acoustics. Whereas good ones are in the worst case acoustics-neutral.
I wholeheartedly disagree but I appreciate it's your experience.
The same speakers pointed across the room's length as opposed to room's width can sound completely different. Shifting listening position by as little as 20cm can make an absolutely massive difference. It's not just the bass response but everything from clarity, tonal balance to soundstage and imaging. And I'm not even talking about extremes like changing listening position from close to a wall to middle of the room. Neither am I taking about also important toe-in or sometimes useful tilting nor mentioning stands, spikes, furnishing or room treatment.
I appreciate the post and in essence agree that the speakers should be a priority. Where our opinions differ is that with enough care correct positioning of speakers in relation to boundaries, speakers themselves and the listener can have a huge impact on what we hear. Too often this aspect is neglected as convenience takes precedence and people are shoving speakers inside cabinets, push them right against the wall, place them too close to one another, etc. the list is extremely long.
This leads to continuos unhappiness. As often no matter what speakers are being used the conditions they're being used in are well against them sounding good. And it's so simple just to say the previous speakers were rubbish, boomy, bright, didn't image well, etc. where it was all down to incorrect use. So people go out and buy another pair that in a shop sound good but sound only slightly less horrible when brought home.
It's a sad state of affairs that people expect improvements just because more money is being spent. But will not consider that a free solution is all they may need.
