Hi im new on here! help ?
hello everyone!
long story short im a dj and i need suitable speakers for mixing!
Ive currently just sold my jamo d 365's for a set of somthing less crap!
my budget is 250 quid!!
i have been looking at Wharfdale diamond 9.1's with a denon amp for 279 pound!
and a set of event 20/20 studio monitors with a krk ns10 amp! for 250 pound!
could anyone please point me in the direction in what to buy!! or make any suggestions?
the type of music i mix is drum n bass / jungle if that is relavent to what speakers to buy!
any help would be much appreiciated! thanks!
cheers for the reply fella!
im using 2 techcnis mk2 1210's!
and bookshelf would be prefered!
and atm i just have a standard old cd player im using to power speakers!
but the denon dm38 amp im thinking with wharfdales ?
im pretty new to all this!!
cheers!
These KRK Rokit 5 Speakers would be ideal. http://www.imuso.co.uk/Studio/Studio-Monitors/9841-/KRK-RP5-Rokit-5-G2-Powered-5-Reference-Studio-Monitor-(Pair)?utm_source=googleproduct They have amplifiers built in, so just plug your mixer into them, ideal for monitoring and can go really loud at party volumes. They can take a fair amount of ware as well. good luck
v1c
79
Not that i'm in anyway an expert here but in your positon and if was was into DJing i would do everything i could to get a pair of Pioneer SDJ05 at £499
pioneer
If that was not possible straight away i would look at starting with a pair of Numark npm5 £80-£99
djkit.com
musicmatter.co.uk
Numark info
Then continue to save for the Pioneers.
thanks very much! ill check out the rokit speakers!
and no its more for bedroom use, something i can use as a home stereo system aswell!
i need something very clear but also very bassy!!
cheers!
thanks for the help on this one!!
i just had a look at the behringer truth b3030a speakers they look good!
but for the quality and the price is there any thing better suited than this package ?
http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/6865
cheers!
